Hi Guys,
Is it possible to include VAT in credit note as well?
I believe it should be the default behavior since is a legal requirement when issuing credit notes on Invoices that VAT was charged.
Thank you in advance.
Antonis
Hi Guys,
Antonis
Yes, itâs supported. Are you seeing a problem?
Thank you Hillel for the prompt response, but where is the VAT option? I donât see anything related to VAT when applying a credit note.
In v4 you can create a âCredit noteâ by creating a negative invoice, the v4 âcreditsâ are pending payments.
Okay understood, thank you Hillel.
Hi Hillel,
One more question, if you create the Credit Note with a negative Invoice, then you should not mark it as paid since it will be subtracted twice from the balance of the customer, right?
You would need to mark it as paid if youâd like it to be applied against the clientâs balance.
Thank you Hillel for the prompt response, my bad, I thought it was subtracted when I was set it as âMark Sentâ and then it was subtracted again when I set it as âMark Paidâ.
I believe mark sent would decrease the clientâs balance whereas mark paid would increase the balance and reduce the paid to date. Since itâs negative itâs the reverse of a standard invoice.
