IN5 has stopped previewing Invoices and Quotes
Version ie <5.13.26>
Environment
Checklist
Describe the bug
Creating or editing an invoice or quote no longer shows a preview.
Creating or amending an Invoice or Quote should show a preivew at the bottom or the right side of the app
Error message is: 500: Internal Server Error • Unable to generate the raw PDF => The process has been signaled with signal “5”.
Logs
Can you please share a screenshot of the health check dialog?
@hillel indeed… Please see the attached, along with a screenshot of the last error.
It’s very odd as it has been fine for a while; it’s only happedned that last few days. I’m just a user, so I don’t do any “messing about” that would upset it..!:sweat_smile:
I should also say that I am using the Yunohost version of IN5
dj
The above are from the OSX desktop app, below is in a browser. More or less the same..
One option to try is to change from snappdf to hosted_ninja as the PDF renderer in the .env file.
@hillel Fantastic. That worked. It must have got changed on an update along the line as it’s been flawless for a few years.
All good again. Thank you so much. I appreciate it.
Dj
