In react UI, search by invoice number won't find anything
Version ie <v5.11.51>
Environment ZIP
Checklist
  • Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja —> no
  • Have you searched existing issues? yes
  • Have you inspected the logs in storage/logs/laravel.log for any errors? yes, there’s nothing happening
Describe the bug
If i search for an invoice number, the search resuilts don’t update. If I search for part of a customer name, it works.
Steps To Reproduce
  • I click the global search bar, the centered search box opens
  • i type an invoice number into the search bar (for example “2025-05379”)
  • The circle moves for 2-3 seconds
  • search results are always the same: a list of customers (a few hundred), at the bottom all open invoices (around 10 for my case, and then a few links to settings.
Expected Behavior
If i search for a complete, existing invoice number, I’d expect to find it, probably even as the only result
Additional context
Screenshots
Logs
I suggest creating an issue on GitHub to track this.
