Hello, I have an instance of InvoiceNinja running in a Docker container on a DigitalOcean 1gb droplet. I am the only one that uses the program or the server and I use very, very seldom. IN and Portainer are the only two things running on this server and I am constantly around 90% memory usage. Is this normal? When I restart the server the memory usage is around 15% for two or three minutes and then it shoots up to around 85% and just stays there with no one using the program.
Docker stats show four containers running…
invoiceninja-server-1----6mb
invoiceninja-app-1-------255mb
maria-db-1-----------------125mb
portainer--------------------9mb
When I actually open the app the memory usage on invoiceninja-app-1 jumps up to 550mb at idle.
Just wanting to check if this is normal for everyone? I’ve upgraded to a 2gb server as I ran into memory issues with just 1gb but I’d like to go back to 1gb if I can.
