I cannot import anything via csv files. Not a problem with my reverse proxy because I tried connecting directly.
It is stuck on “processing”.
I just did a fresh install, the problem persists.
Importing csv via Import Export over the Settings is not an option anymore.
To input every customer and invoice by hand would be a nightmare. Can anyone help?
@david @ben I’ve seen a few reports of this.
Note: it may help to try with the desktop app.
david
3
Are you on .49 ? i’ve just tested on my docker setup and the import works fine?
I just updated with a pull, but still no luck via the web ui.
Using the desktop App it is working. I’m using the react version of the web app.
I’m on version v11.03.2024.1
david
5
@aronjanosch
How have you installed the application?
If you navigate to /index.html
do you see a different version?
