loc
December 2, 2020, 7:02am
1
Hi new to InvoiceNinja coming from Wave.
I’ve searched the Forums and there was another similar topic but it doesn’t solve the issue i’m having.
I have followed the instructions and exported from Wave and imported into IN but it only seems to do 1 invoice?
is there some prep work that i should be doing in the CSV file for it to import all the invoices?
December 2, 2020, 7:47am
I suggest using the CSV option to import the invoices rather than ‘Wave’, I think their format has changed since the feature was added.
Good day. I have also tried to import and and this was via a CSV file but I continuously receive a notification that asks me to confirm my account via email, which I have done. Kindly assist
December 7, 2020, 8:38am
4
Do you see a ‘resend confirmation email’ option on Settings > User Details?
Yes I do and I have followed the prompts to do so
I tried again this morning and it seemed to have worked. Thanks
loc
December 9, 2020, 4:31am
7
i just tried exporting to csv and then on import set the matching columns but i keep getting errors and nothing gets imported?
did you have to sort any columns specifically?
thanks for any help
December 9, 2020, 6:17am
8
What specific error are you seeing?
The column sorting shouldn’t matter as the fields can be mapped
loc
December 10, 2020, 12:10am
9
thank you for your help. really appreciate it.
i always get this error.
The following records failed to import, they either already exist or are missing required fields.
{“name”:“Client Name Here”,“email”:false,“invoice_number”:“1920.584”,“po_number”:false,“invoice_date”:“10/03/2020”,“due_date”:false,“paid”:false,“terms”:false,“public_notes”:false,“private_notes”:false,“item_product”:false,“item_notes”:“CLIENT NOTES HERE - 1920.584”,“item_quantity”:false,“item_cost”:“0000”,“item_tax1”:“GST”,“item_tax2”:false}
December 10, 2020, 5:45am
10
Thanks! Does the client exist and is the invoice number available?
loc
December 10, 2020, 5:58am
11
hi. yes i imported the clients successfully. i had to make some changes to some details but generally the clients imported ok.
i’m not sure what you mean by the invoice number available? but it’s bringing it in from the export?
December 10, 2020, 8:32am
12
For example, maybe an invoice already exists with the invoice number but is deleted
loc
December 10, 2020, 10:51am
13
ah that might be it. but i couldn’t figure out how to delete the deleted invoices?
December 10, 2020, 10:56am
14
If you’re getting started you can purge the company data on Settings > Account Management
loc
December 10, 2020, 12:14pm
15
Ok thanks I’ll do that and start again. Cheers.
loc
December 10, 2020, 10:59pm
16
i purged and tried again still same error.
the logs are saying either exist which i know it doesn’t after a purge so it must be missing required fields. but which fields are required?
thanks for your help. really do appreciate it.
December 11, 2020, 5:06am
17
Did you reimport the clients after purging the data?
December 11, 2020, 6:08am
19
Sorry, I don’t have any other advice to share. In my experience this error either means the client didn’t match or the invoice number is taken.
