is it possible to migrate the old pdf templates from v4 to v5?
I get errors all the time if i try to add a new template. If i try to save it and update all invoices it says there is not such a template.
v5 templates are now created using HTML/CSS so aren’t compatible with v4.
Which version of the app are you using? If you can share a screen recording showing the problem it may help us track it down.
