Import / Export
Hello im testing Invoice Ninja with Docker Desktop for Windows. Language is set to German.
If have problems to import Products. I Exportet 3 Items
Added 2 with a other Name and with the same strukture but when i want to upload it gives me an issue.
grafik
Can you help ?
Does the filename end with .csv?
Yes it ends with csv
Do you see a difference using the desktop app?
