Is there an working procedure for making install under IIS8 (Windows 2012 R2)?
I have search here in forum and I have not found any hint.
And also where is most appropriate place for feature suggestions?
Thnx
Thnx
Sorry, not sure about IIS. I’d suggest searching for “Laravel IIS”.
You can create issues on our GitHub repo for feature requests.
I installed Laravel (for testing purpose) and following installation I found that in IIS the web site for InvoiceNinja must point to the \public folder not to the root folder. Now is working.
