I’m trying to setup iDeal via Mollie, but i get the 500 server error.
Output from laravel.log:
[2021-10-29 13:46:50] production.ERROR: Class ‘Mollie\Api\MollieApiClient’ not found {“userId”:168,“exception”:"[object] (Error(code: 0): Class ‘Mollie\Api\MollieApiClient’ not found at /www/wwwroot/jornmeijs.nl/administratie/app/PaymentDrivers/MolliePaymentDriver.php:80)
#0 /www/wwwroot/jornmeijs.nl/administratie/app/PaymentDrivers/Mollie/IDEAL.php(36): App\PaymentDrivers\MolliePaymentDriver->init()
#1 /www/wwwroot/jornmeijs.nl/administratie/app/PaymentDrivers/MolliePaymentDriver.php(106): App\PaymentDrivers\Mollie\IDEAL->__construct()
#2 /www/wwwroot/jornmeijs.nl/administratie/app/Services/ClientPortal/InstantPayment.php(270): App\PaymentDrivers\MolliePaymentDriver->setPaymentMethod()
#3 /www/wwwroot/jornmeijs.nl/administratie/app/Http/Controllers/ClientPortal/PaymentController.php(83): App\Services\ClientPortal\InstantPayment->run()
#4 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\ClientPortal\PaymentController->process()
#5 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction()
#6 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Routing/Route.php(254): Illuminate\Routing\ControllerDispatcher->dispatch()
#7 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Routing/Route.php(197): Illuminate\Routing\Route->runController()
#8 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Routing/Router.php(695): Illuminate\Routing\Route->run()
#9 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#10 /www/wwwroot/jornmeijs.nl/administratie/app/Http/Middleware/QueryLogging.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#11 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\QueryLogging->handle()
#12 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#13 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#14 /www/wwwroot/jornmeijs.nl/administratie/app/Http/Middleware/Locale.php(34): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#15 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Locale->handle()
#16 /www/wwwroot/jornmeijs.nl/administratie/app/Http/Middleware/CheckClientExistence.php(60): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#17 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\CheckClientExistence->handle()
#18 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(44): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#19 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Auth\Middleware\Authenticate->handle()
#20 /www/wwwroot/jornmeijs.nl/administratie/app/Http/Middleware/SetDomainNameDb.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#21 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\SetDomainNameDb->handle()
#22 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(78): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#23 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#24 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#25 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#26 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#27 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\Session\Middleware\StartSession->handleStatefulRequest()
#28 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Session\Middleware\StartSession->handle()
#29 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#30 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#31 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#32 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#33 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#34 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Routing/Router.php(697): Illuminate\Pipeline\Pipeline->then()
#35 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Routing/Router.php(672): Illuminate\Routing\Router->runRouteWithinStack()
#36 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Routing/Router.php(636): Illuminate\Routing\Router->runRoute()
#37 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Routing/Router.php(625): Illuminate\Routing\Router->dispatchToRoute()
#38 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(166): Illuminate\Routing\Router->dispatch()
#39 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#40 /www/wwwroot/jornmeijs.nl/administratie/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(55): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#41 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#42 /www/wwwroot/jornmeijs.nl/administratie/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(52): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#43 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#44 /www/wwwroot/jornmeijs.nl/administratie/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#45 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Cors->handle()
#46 /www/wwwroot/jornmeijs.nl/administratie/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#47 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle()
#48 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#50 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#51 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#52 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#53 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#54 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#55 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#56 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#57 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#58 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#59 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(141): Illuminate\Pipeline\Pipeline->then()
#60 /www/wwwroot/jornmeijs.nl/administratie/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#61 /www/wwwroot/jornmeijs.nl/administratie/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle()
#62 {main}
Is there a way to fix this?
Thanks in advance.
