I am trying configure cron on my server Plesk but i can’t.
If i execute cron from console, i recive this error:
Any suggestion?
Thanks!
Any suggestion?
Thanks!
I have already solved. I need to install this on my Ubuntu server with Plesk.
sudo apt-get install php7-mysql
But inside the control panel it shows an error with the cron and says that it is not enabled. I attach a capture.
Have you tried refreshing the data in the app after the cron has run?
Yes but nothing happens.
Are you using the latest version of the app?
Are you sure the cron is now running/are email sending?
My version is v5.0.56-C46. I attach a capture of my cron when i execute manually in Plesk.
My command cron is:
cd mydirectoydomain.com && /opt/plesk/php/7.4/bin/php ‘artisan’ schedule:run
Execute every * * * * *
Thanks!
@david any thoughts?
the migration may not have run?
can you try
php artisan migrate
Yes.
php artisan migrate
Application In Production! *
Do you really wish to run this command? (yes/no) [no]:
yes
Nothing to migrate.
For me it does not work like this, and i had to use httpdocs and not the domain. have you done any other modifications? Maybe you encountered the same issue as me? Issue with Cron on plesk - #3 by Alex_The_Penguin
