I have a problem with HTTPS. I’ve hosted invoice-ninja on docker.
When I set:
APP_URL=https://invoice.test.com
REQUIRE_HTTPS: true
and after running docker-compose and navigating to https://invoice.test.com
I receive an error:
ERR_CONNECTION_REFUSED
After changing:
REQUIRE_HTTPS: false
I can navigate to http://invoice.test.com
My docker-compose:
version: "3.9"
services:
invoice-ninja-server:
image: nginx
container_name: invoice-ninja-server
hostname: invoice-ninja-server
ports:
- 80:80
- 443:443
environment:
- DB_HOST=127.0.0.1
- DB_PORT=3306
- DB_DATABASE=invoice
- DB_USERNAME=invoice
- DB_PASSWORD=invoice
volumes:
- /path/to/Caddy/Caddyfile:/etc/caddy/Caddyfiledocker-com
- /path/to/invhost/in-vhost.conf:/etc/nginx/conf.d/in-vhost.conf
- /path/to/app/public:/var/www/app/public
depends_on:
- invoice-ninja-app
restart: always
labels:
logging:
driver: "json-file"
options:
max-size: "10M"
max-file: "7"
labels: "hostname"
invoice-ninja-app:
image: invoiceninja/invoiceninja:5.5
container_name: invoice-ninja-app
hostname: invoice-ninja-app
ports:
- 9000:9000
environment:
- APP_URL=https://invoice.test.com
- APP_KEY=<key>
- APP_CIPHER='AES-256-CBC'
- APP_DEBUG=true
- APP_NAME=Invoice
- REQUIRE_HTTPS=true
- PHANTOMJS_PDF_GENERATION=false
- PDF_GENERATOR=snappdf
- TRUSTED_PROXIES='*'
- QUEUE_CONNECTION=redis
- DB_HOST=127.0.0.1
- DB_PORT=3306
- IN_USER_EMAIL=ninja
- IN_PASSWORD=ninja
- CACHE_DRIVER=redis
- SESSION_DRIVER=redis
- REDIS_HOST=127.0.0.1
- REDIS_PORT=6379
- IS_DOCKER=true
- NINJA_ENVIRONMENT=selfhost
- BROADCAST_DRIVER=pusher
volumes:
- /path/to/host/hosts:/etc/hosts
- /path/to/app/storage:/var/www/app/storage
restart: always
labels:
logging:
driver: "json-file"
options:
max-size: "10M"
max-file: "7"
labels: "hostname"
networks:
default:
external: true
Do I do something wrong with the configuration or should I change something in in-vhost.conf
file?
Best regards!
