When creating quotes i frequently use HTML TAGS such as
< br> and < font size=“2”>
But since the last update it doesnt show up anymore when i’m using those tags.
It is suposed to look like this…
I suggest sending an email to [email protected] to ask.
Couple issue I can see here.
tags are sanitized now. These are deprecated and no longer will work.
I can see that you are using this in combination with markdown.
the best way to achieve the results are you after:
Font sizes use #
# Largest
## Medium
### Smaller
For new lines use two spaces and then hit return
or
use br tags like this:
Thank you.
When i use ### it is not smaller then the invoice font.
And # or ## are waaaay to big.
Thanks.
The best way to achieve this with html markup would be as follows:
Test
Hello @david ,
without using the “Preformatted Text / Code” feature, we cannot see your HTML tags.
At least on my side they are not visible…
Could you please repost your advice?
Example:
With preformatted text feature: <br>
Without preformatted text feature:
here is a great resource for exactly this:
It goes through the markdown and html options on a line by line basis:
For font sizing:
<p style="font-size:12px;">Font Sized</p>```
