I’m willing to update from 2.8.1 to 2.8.1. I read the guide but didn’t understand how
To update the app you just need to copy over the latest code. The app tracks the current version in a file called version.txt, if it notices a change it loads /update to run the database migrations.
unzip ninja-VERSION.GOES.HERE.zip
cd ninja
rsync -vtr . /var/www/YOUR.WEBSITE.COM/
This assumes:
You download the zip from the website, not git clone the repo.
Unzipping the zip creates the folder ninja (which it typically does).
The “.” in the rsync command refers to the everything you just unzipped as the source, this method also includes hidden files.
You will need to re-set permissions on the files after doing this (in the location you just copied the files to), which is pretty easy, but worth saying.
