How to show "standard" invoice terms on invoice
Version ie <v5.10.30>
Environment Shared Hosting
Describe the bug
How can I show the “standard” invoice terms (under settings → company → standrards) on the invoices ($terms). Only if I type in the invoice terms in a dedicated invoice the terms are shown on the invoice, but not the standard ones if I do not have any invoice terms in the dedicted invoice.
Thank you very much
Steffen
Are you using a standard or custom design?
Hello, I found the issues. Seems to be on my side. The generated Invoice in status “Draft” is not updating if I change these settings. If I create a new Draft invoice it’s working fine.
Glad to hear it’s working, thanks for the update!
