How to receive e-invoices
I just came across the great regulation and the requirement for e-invoices in the EU from January 2025. And I was very pleased to see that InvoiceNinja already has a function for sending these electronic invoices.
I tried it out and it worked straight away. Very neat work. Many thanks for that!
But now I’m wondering how I should receive electronic invoices that are sent to me in such an electronic format by other companies? Is there a solution for this in Ninja? So far I have always entered my expenses (incoming invoices) manually. Will there be a way to import e-invoices directly into Ninja? Ideally through an email inbox that is connected via IMAP or POP3, for example?
If something like this is not available or planned: Can anyone give me tips on other software that can receive such invoices and display them legibly without me getting caught in the license swamp of commercial software?
many thanks, Kai
I suggest searching for a relevant issue on GitHub
Thanks for your link. I can´t find any “issue” regarding this.
If it´s not supported by InvoiceNinja its a kind of “feature request” instead an issue.
It´s a logical need in Invoiceninja for the upcoming eu wide need of e-invocies from 2025: Send & receive electronic invoices
Feel free to create a new issue
Did it:
