How to print invoice-amount without taxes in twig-templates?
Hey guys,
I’m playing with the new templates. And it seems there’s no variable for the tax-less invoice-amount.
I tried to make a substraction, but this won’t work with the amount-variable. It seem’s it’s because it’s not just a number, even it’s declared as a number there: API-docs (look into the schematics at the bottom of this page)
Can you help?
@david can you please advise?
invoice.amount - invoice.total_taxes
That’s what I did:
{{ invoice.amount - invoice.total_taxes }}
All I get is: “Something went wrong” (in German). :frowning:
@Schmitti
I think the correct syntax would be
{{ invoice.amount_raw - invoice.total_taxes_raw }}
These are the double values of the fields, the other ones, are the formatted strings.
Hi, @david,
I know, I already found that out. The problem is, that if I take the raw values I need a workaround for the right and variable formating of the currency.
For example: In Germany we write: “1.000,00 €”, but I heard that in Austria it’s like “€ 1.000,00” or USA “$1,000.00” or something.
At least it would be cool if we had the chance to use every important variable like totals with and without taxes and so on.
It’s really a little struggle to create fully customized templates. :-/
@Schmitti so this is certainly possible, using twigs format_currency() filter
ie.
{{ '1000000'|format_currency('EUR', locale='de') }}
{{ '1000000'|format_currency('EUR', locale='at') }}
Just to note, this will require php-intl extension to be installed. It also requires an update to the template variables so that we expose the locale, in this example the code would look like this:
{{ invoice.amount|format_currency(invoice.client.currency, locale=invoice.client.locale) }}
the locale variable will be available in 5.9.3
Hey @david!
Thanks a lot! Wow, this looks like a profession to learn. I would love to have the time to study and learn everything about it.
At this moment I have to thank you again for your valuable help and your enthusiasm you donate into this project!
Greets
Schmitti
Hey, @david ,
after analysing your code I did a 'lil research and found out the right code for me:
{{ (invoice.amount_raw - invoice.total_taxes_raw)|format_currency(invoice.client.currency, locale=invoice.client.locale) }}
Thanks a lot!
