ovizii
July 31, 2018, 10:29pm
1
Hi there,
I just found the list of all supported gateways: https://www.invoiceninja.com/integrations/ which leads me to SOFORT: https://www.invoiceninja.com/payments-sofort/
Unfortunately I can’t find SOFORT in the dropdown. Am I looking in the wrong place? Invoiceninja => Settings => Online Payments => Add Gateway => More Options
I am using invoiceninuja as a self-hosted docker solution if that matters.
ovizii
July 31, 2018, 10:32pm
oh, if I select Stripe, I see SOFORT as an option, is that part of the Stripe solution? I was under the impression it was a standalone solution?
July 31, 2018, 10:36pm
3
Correct, it’s supported through Stripe.
ovizii
July 31, 2018, 11:12pm
5
oh, another side note: I can only see Paypal Express and Paypal Pro in the list of gateways. It looks like with a European account I don’t get Paypal PRO but Paypal Plus although I’m not quite sure. Apparently PLUS can SEPA payments.
Is PLUS not available through invoiceninja?
August 1, 2018, 12:36am
6
ovizii
August 1, 2018, 12:46am
7
Thanks, then I guess Paypal Express has to do for now.
ovizii
August 1, 2018, 1:26am
8
@hilel I am no coder so I googled: “omnipay paypal plus” and found this: https://github.com/mikoweb/omnipay-paypal-plus
Does that somehow help?
August 1, 2018, 1:34am
9
ovizii
August 1, 2018, 1:49am
10
Thanks, I opened a ticket as I don’t know if / how this can be added to the docker version without losing this with the next update. => https://github.com/invoiceninja/dockerfiles/issues/80
I don’t have Stripe here. What am I doing wrong?
August 6, 2018, 6:04am
12
If you’ve enabled another credit card gateway you’ll need to archive it.
I have now only PayPal, GoCardless and BitPay. Which one is considered to be credit card gateway?
Does it mean that I can not use Sofort together with one of these payment systems?
August 6, 2018, 9:44pm
14
Sofort is supported through Stripe.
I figured out, that Stripe can be connected only if I delete GoCardless.
So I can not use them simultaneously?
Either Stripe or GoCardless?
August 8, 2018, 6:44am
16
That is correct, one or the other.
