No matter which template I use, the footer is not fixed at the bottom but only with a defined distance to the total_table.
How can a footer be fixed on bottom?
In V4 I could create the following footer:
@ben do you have any suggestions?
In order to make sticky footer you will need to CSS. Have a look at some examples.
As far as I know, Bold & Modern have sticky footers.
Thanks for examples. It works fine.
