I am having trouble filtering invoices while consuming the API…
For instance, https://invoicing.co/api/v1/invoices?client_id=xxxx works but filtering by status_id has no effect.
For example, I am trying to get all invoices from a certain client that have an open balance and that were not deleted.
I understand that the clients endpoint gives me the balance for a certain client but I need to know how old the actual invoice is.
The documentation is not very clear, plus I believe that it has a typo…
Lists invoices, search and filters allow fine grained lists to be generated. * * Query parameters can be added to performed more fine grained filtering of the invoices, these are handled by the InvoiceFilters class which defines the methods available
