here is a short HOW-TO on how to create a contact using Integromat. Due to an error in the module Create a client, you can create a client with all its details but contact details. The parameters for the contact(s) is simply missing in the module.
- Choose another module called Make an API Call
Choose /v1/clients/[CLIENT-ID] as the URL. Make sure to swap [CLIENT-ID] with the pill from the Module “Create a client”. The “Create a client” Module has the Client ID in the response. Use this reponse to get the Client ID which is needed to create the contatc(s).
Choose PUT as Method.
Enter the body.
Example body for only 1 contact
"contacts": [
"first_name": "PUT FIRST NAME HERE",
"last_name": "PUT LAST NAME HERE",
"email": "PUT EMAIL HERE",
"is_primary": true,
"phone": "PUT PHONE HERE",
"custom_value1": "PUT CUSTOM V. HERE",
"custom_value2": "PUT CUSTOM V. HERE",
"custom_value3": "PUT CUSTOM V. HERE",
"custom_value4": "PUT CUSTOM V. HERE"
Example body for multiple contacts
"contacts": [
"is_primary": true,
"is_primary": false,
(click for details)
Greetings from Berlin,
Gijs
