Yes we have seen this information.
We tried installing it by
“composer require beganovich/snappdf”
but we always run into problems with some dependencies:
root@LiveBilling:/var/www/html/invoiceninja# composer require beganovich/snappdf
Do not run Composer as root/super user! See https://getcomposer.org/root for details
Continue as root/super user [yes]? yes
Info from https://repo.packagist.org: #StandWithUkraine
Using version ^2.1 for beganovich/snappdf
./composer.json has been updated
Running composer update beganovich/snappdf
Loading composer repositories with package information
Updating dependencies
Your requirements could not be resolved to an installable set of packages.
Problem 1
- Root composer.json requires beganovich/snappdf ^2.1 → satisfiable by beganovich/snappdf[v2.1.0].
- beganovich/snappdf v2.1.0 requires symfony/process ^6.0 → found symfony/process[v6.0.0-BETA1, …, 6.1.x-dev] but the package is fixed to v5.4.7 (lock file version) by a partial update and that version does not match. Make sure you list it as an argument for the update command.
Use the option --with-all-dependencies (-W) to allow upgrades, downgrades and removals for packages currently locked to specific versions.
You can also try re-running composer require with an explicit version constraint, e.g. “composer require beganovich/snappdf:*” to figure out if any version is installable, or “composer require beganovich/snappdf:^2.1” if you know which you need.
Installation failed, reverting ./composer.json and ./composer.lock to their original content.
root@LiveBilling:/var/www/html/invoiceninja# composer require beganovich/snappdf --with-all-dependencies
Running composer update beganovich/snappdf --with-all-dependencies
Problem 1
- beganovich/snappdf v2.1.0 requires symfony/process ^6.0 → found symfony/process[v6.0.0-BETA1, …, 6.1.x-dev] but these were not loaded, likely because it conflicts with another require.
root@LiveBilling:/var/www/html/invoiceninja# composer require symfony/process
Using version ^6.0 for symfony/process
Running composer update symfony/process
Problem 1
- Root composer.json requires symfony/process ^6.0, found symfony/process[v6.0.0-BETA1, …, 6.1.x-dev] but these were not loaded, likely because it conflicts with another require.
Problem 2
- asm/php-ansible is locked to version v3.0.1 and an update of this package was not requested.
- asm/php-ansible v3.0.1 requires symfony/process ^4.0|^5.0 → found symfony/process[v4.0.0-BETA1, …, 4.4.x-dev, v5.0.0-BETA1, …, 5.4.x-dev] but it conflicts with your root composer.json require (^6.0).
Problem 3
- beganovich/snappdf is locked to version v1.10.0 and an update of this package was not requested.
- beganovich/snappdf v1.10.0 requires symfony/process ^5.2 → found symfony/process[v5.2.0-BETA1, …, 5.4.x-dev] but it conflicts with your root composer.json require (^6.0).
Problem 4
- laravel/framework is locked to version v8.83.9 and an update of this package was not requested.
- laravel/framework v8.83.9 requires symfony/process ^5.4 → found symfony/process[v5.4.0-BETA1, …, 5.4.x-dev] but it conflicts with your root composer.json require (^6.0).
Problem 5
- brianium/paratest is locked to version v6.4.4 and an update of this package was not requested.
- brianium/paratest v6.4.4 requires symfony/process ^5.4.0 || ^6.0.0 → found symfony/process[v5.4.0-BETA1, …, 5.4.x-dev, v6.0.0-BETA1, …, 6.1.x-dev] but these were not loaded, likely because it conflicts with another require.
Problem 6
- friendsofphp/php-cs-fixer is locked to version v2.19.3 and an update of this package was not requested.
- friendsofphp/php-cs-fixer v2.19.3 requires symfony/process ^3.0 || ^4.0 || ^5.0 → found symfony/process[v3.0.0-BETA1, …, 3.4.x-dev, v4.0.0-BETA1, …, 4.4.x-dev, v5.0.0-BETA1, …, 5.4.x-dev] but it conflicts with your root composer.json require (^6.0).
Problem 7
- laravel/dusk is locked to version v6.23.0 and an update of this package was not requested.
- laravel/dusk v6.23.0 requires symfony/process ^4.3|^5.0|^6.0 → found symfony/process[v4.3.0-BETA1, …, 4.4.x-dev, v5.0.0-BETA1, …, 5.4.x-dev, v6.0.0-BETA1, …, 6.1.x-dev] but these were not loaded, likely because it conflicts with another require.
Problem 8
- facade/ignition 2.17.5 requires illuminate/support ^7.0|^8.0 → satisfiable by laravel/framework[v8.83.9].
- facade/ignition is locked to version 2.17.5 and an update of this package was not requested.
You can also try re-running composer require with an explicit version constraint, e.g. “composer require symfony/process:*” to figure out if any version is installable, or “composer require symfony/process:^2.1” if you know which you need.
Are we forgetting something or doing something wrong?
How can we get rid of these dependency problems?
