How to change plan
I mimgrated from version 4 to 5.
In account management, I see that I have an enterprise plan but how can I change it?
Thx
Are you selfhosting the app are you using the hosted version?
I’m using the hosted one
You can change plans in the client portal, there should be a view portal link on Settings > Account Management.
hi,
This doesn’t help because I received this:
And I can’t make a subscription because you need the paid version so i’m in a loop !
@david can you please advise?
@GiGisComputers
Please send us an email [email protected] and we can look into this for you.
I have the same problem. It appears V4 is still set to enterprise plan but I cannot turn it on for V5
