I want to add custom date format to list at localization settings. I added a row into tables data_formats and datatime_format, but it didn’t appear at the list.
I’m not sure if this is supported but it may help to clear the backend cache by loading /update?secret= as well clear the frontend data by clicking ‘Refresh data’ on Settings > Device Settings.
Still nothing. It must be not supported.
Is there an option to create a custom date format for invoices?
@david can you please advise?
you need to refresh the cache using /update?secret=secret
This works, using just “/update?secret=” doesn’t.
