How to add a custom payment gateway in Invoice Ninja ?
I’m using Invoice Ninja to manage invoices and payments, but unfortunately my local payment provider is not supported out of the box. The provider gives me a REST API with:
API Key / Secret
Endpoints to create a payment and check the transaction status
A Webhook to receive payment notifications
My questions are:
What are the correct steps to create a custom PaymentDriver inside Invoice Ninja ?
In which folders/files should I place the code?
Is there any working example or template that I can adapt to integrate with any local API?
Any guidance or sample code would be very helpful.
Thanks in advance.
Have you seen the docs here?
