How to add a custom field (long text) to an Invoice Template?
Hi all,
Is there the best practice to add a long text (custom field) to an invoice template?
I would like to write a few sentences in a custom field and then add it to the invoice template.
Kind regards,
Mokjin
One option may be to use the invoice terms.
If you want to use a custom field you can then use a custom invoice design and add it.
