How is it possible to use 'Description' in reminder template?
How can I use description items in template (see screenshot attached)???
@akushyn
This isn’t supported.
You could use a custom field to store this data, and then use the custom field in your templates.
is it possible to have more than 4 custom fields ?
4 custom fields is the current hard limit
