Hello
just installed the system and out of curiosity as we were browsing the system we attempted to connect Zapier and in that process you get the popup:
Using that link would just create cloud hosted option that you do not need when yo host yourself and I suspect that the API key will also be linked to the cloud version.
So how do you create your API key on your self hosted/on-premise version?
Thanks a bunch in advance for the help.
Kind regards
AngryWarrior
There is an option to manage token on Settings > Account Management
Note: make sure you’re using the v5 version of the Zapier integration.
https://zapier.com/developer/public-invite/95884/5e4368b9efb9d377dc0a0b0465b7c1a7
I saw that but clicking on it does nothing:
As you can see it just shows blank space. No option to generate a key…
Kind regards
AngryWarrior
There is a plus icon at the top of the screen to add a new record
Thanks!
I completely missed it…
Kind regards
AngryWarrior
