How can I make Landscape invoice
pageOrientation: ‘landscape’ code is not running and I can’t find landscape option in invoice ninja settings.
I’m not sure if it’s supported, you may need to modify the code to enable it.
i’m edit celan.js file in template folder. But not working
If you change the clean.js file you’d also need to update the database.
php artisan db:seed --class=UpdateSeeder
Problem is solved after update thank you Hillel Coren
