When you are using more columns than the widht of your screen, you don’t get horizontal scrollbars.
Is this a setting that i missed…
Koen
Koen
The scrollbar should appear if you hover over the bottom of the table.
I see only the vertical one on the right… nothing at the bottom…
Using Google Chrome, I’ll try some other browsers…
Koen
Not sure, I see it in Chrome
Tried in Edge and Chrome…
No horizontal scrollbars… or do i something wrong?
Koen
You need to scroll down (or reduce the number of rows) to see the horizontal scroll bar.
Ok Hillel,
Is it normal i have a bunch of empty lines before the scrollbars appear?
Koen
That will happen if you’ve selected to show more rows than there are.
The issue is being tracked here: Blank rows shown if there are not enough entries to display · Issue #492 · invoiceninja/admin-portal · GitHub
