Hi there,
I’ve just installed InvoiceNinja, and I think there is an issue with Hipster template. After I entered some data it looks like this Preview
Is there any possibility to fix this ?
thanks
Hi there,
thanks
We’ll look into fixing this in our next release.
You may be able to improve it with these steps:
Thank you ! It works like a charm, the only thing, I put 40.4% to solve the issue
SOLVED !
