I have a couple small issues with invoice design and it’s mostly because I’m not very familiar with html, I think.
First, when I enable shipping address it displays the city state and zip on three separate lines. For example:
123 Main St
Beverly Hills
CA
90210
Secondly, I’m using the Clean invoice and would like to add more margin to the top of the page. My logo and company info is very close to the top of the page. I would like to move it down a little.
Can anyone give me some guidance on these two things? I’ve tried searching and haven’t been able to find anything to fix these issues. Thanks if you can help. I’m on 5.5.113 if that matters.
@david@hillel is correct. My request is that the two addresses match. I pulled up the demo site and the two addresses match there. Maybe this is a bug in the self hosted version?
I understand the request here. The concern with making these types of changes is invariably we make one group satisfied with the change, and another group unhappy that there has been a change.
I’ve made this particular change which will be available in the next release, but my preference for these types of changes would be to have them configurable in the UI.
I fully understand your concern. I deal with that frequently at my work. It would definitely be nice if this were configurable in the UI in the future. Hopefully this change won’t cause you too much feedback.
Thank you for your help. I really appreciate that you all are so active and helpful with the community. It truly means a lot.
