I’m looking for a bit of help getting the client ID via a CURL command, basically finding the ID by email address so I can do a quick if they exist update, if not create command.
This is what I have so far, but I can’t find a way to grab the ID from the array
I’m using self-hosted
<?php
function cURLclients($url) {
// Create a new cURL resource
$curl = curl_init();
if (!$curl) {
die("Couldn't initialize a cURL handle");
// Set the file URL to fetch through cURL
curl_setopt($curl, CURLOPT_URL, "https://MYURLapi/v1/clients?email=" . $url);
// Follow redirects, if any
curl_setopt($curl, CURLOPT_FOLLOWLOCATION, true);
// Fail the cURL request if response code = 400 (like 404 errors)
curl_setopt($curl, CURLOPT_FAILONERROR, true);
// Return the actual result of the curl result instead of success code
curl_setopt($curl, CURLOPT_RETURNTRANSFER, true);
// Wait for 10 seconds to connect, set 0 to wait indefinitely
curl_setopt($curl, CURLOPT_CONNECTTIMEOUT, 10);
// Execute the cURL request for a maximum of 50 seconds
curl_setopt($curl, CURLOPT_TIMEOUT, 50);
curl_setopt($curl, CURLOPT_CUSTOMREQUEST, "GET");
curl_setopt($curl, CURLOPT_POST, "GET === 'POST' ? 1 : 0");
$token = 'MYTokEN';
curl_setopt($curl, CURLOPT_HTTPHEADER, [
'Content-Type: application/json',
'X-Ninja-Token: '. $token,
// Do not check the SSL certificates
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, false);
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, false);
// Fetch the URL and save the content in $html variable
$html = curl_exec($curl);
// Check if any error has occurred
if (curl_errno($curl))
echo 'cURL error: ' . curl_error($curl);
else
// cURL executed successfully
return $html;
// close cURL resource to free up system resources
curl_close($curl);
$clients = cURLclients('email@tofind.com');
$clients = str_replace('"', "", $clients);
$convert_to_array = explode(',', $clients);
for($i=0; $i < count($convert_to_array ); $i++){
$key_value = explode(':', $convert_to_array [$i]);
$end_array[$key_value [0]] = $key_value [1];
print_r($end_array);
$reversed = array_flip($end_array);
echo "<br><Br><br>";
print_r($reversed);
echo "<br><Br><br>::";
$count = (count($end_array));
if ($count <10) {
//CREATE NEW RECORD
echo "nothing";
else {
echo "found it";
//UPDATE RECORD
