system
1
I am getting redirected to a 403 Forbidden Error when trying to save or e-mail an invoice.
You don’t have permission to access /public/invoices on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
I checked folder permissions and they are set to 755 and files to 644.
I’m self hosting on shared hosting and installed Invoice Ninja with Softaculous.
Can you check that the files are owned by the webroot.
Softaculous may also be able to provide help.
system
3
The owner and group is shown as my cpanel login name in my FTP client. How can I set it to webroot?
4
If you have SSH access you can run sudo chown -R www-data:www-data storage, I’m not sure with a cpanel.
Are you only seeing this error when saving an invoice? Was this always a problem or did it start happening. Also, which version are you using?
system
5
Thanks for your help, the issue turned out to be a security setting on the shared hosting and is resolved now.
Can you tell us what the shared hosting error was so others can benefit from the solution?
