Help understanding generated numbers and reoccurring invoices
I’m trying to set up my invoice generated numbers to be year-counter(2024-0001) and increment each time an invoice is generated. In the generated numbers setting section I currently have {$year}-{$counter} in the reoccurring prefix box but when I look at my reoccurring invoice it had (001). I tried to put in the same variable as in the settings but that’s all it shows on the invoice preview. It doesn’t convert the variable to the year-counter format I’m expecting.
All I’m wanting is all invoices and reoccurring invoices to use this format and reset every year. I also have the quotes and po’s using the same format.
Right now when I make a new reoccurring invoice I manually change the invoice number but I just want to use the variables so as I set up new invoices I don’t have to manually change the invoice number.
Thank you for helping me understand this. Maybe I’m overthinking it.
Here is my generated numbers settings.
I believe you want to enter that value as the pattern on the invoices and recurring invoices tabs and clear the prefix value.
So I did that and my invoice went out last night with the variables as the invoice number. It didn’t translate the variables.
My invoice number was {$year}-{$counter}. Is that the correct format? Thank you
That looks correct, can you share screenshots of your settings?
Looks like it’s working now. I went through and put the year-counter variable for each type and my expense and invoices now have the new format. I won’t know until next month if the reoccurring invoice will show correctly. But I will post back after it sends. Thank you.
