Version ie <v5.13.26>
Environment
Describe the bug
After Upgrading from 5.13.19 to 5.13.26, the health check is showing the following message
PHP
web: 8.5.4
cli: PHP 8.5.4 (cli) (built: May 25 2026 12:19:37) (NTS)
Memory: 1024M
API: 5.13.26
recent errors
[2026-07-04 20:44:28] production.WARNING: Using null as an array offset is deprecated, use an empty string instead in /usr/share/nginx/invoiceninja/vendor/awobaz/compoships/src/Database/Eloquent/Relations/HasOneOrMany.php on line 283
Logs
[2026-07-04 20:28:45] production.WARNING: strlen(): Passing null to parameter #1 ($string) of type string is deprecated in /usr/share/nginx/invoiceninja/app/Http/Controllers/SmtpController.php on line 38
[2026-07-04 20:33:59] production.WARNING: Using null as an array offset is deprecated, use an empty string instead in /usr/share/nginx/invoiceninja/vendor/awobaz/compoships/src/Database/Eloquent/Relations/HasOneOrMany.php on line 283
