OK, tried for a day and a half (unsuccessfully) to install a V5 version on Ubuntu 20.04/Apache so now I’m need of some expert guidance. I HAD a fully functioning version of V5 and the buggy PDF generation stopped working so I thought would try to install a fresh version in a new directory and port the data over but it’s not working and I’m stuck!
I am unable to save invoices (timeout error) or generate PDF’s and it all seems to be tied to the following laravel errors: [stacktrace] [2021-10-26 15:15:41] production.ERROR: file_get_contents(https://inv5.myriad.ca/images/new_logo.png): failed to open stream: Connection timed out {"userId":1,"exception":"[object] (ErrorException(code: 0): file_get_contents(https://inv5.myriad.ca/images/new_logo.png): failed to open stream: Connection timed out at /var/www/invoiceninjav5/app/Models/Presenters/CompanyPresenter.php:73)
Laravel PDF error: [stacktrace] [2021-10-25 20:48:41] production.ERROR: The file "/var/www/invoiceninja/public/storage/Zh3KnSJFS59Zc9RTh3hOryuBmvX7qNkvYiC1NaJykhKuFevmgxrmEbF1rEU106Hf/IYWF3oXZ94n9oHUTd9mFrXJVeY1X3pfTKWY45uwp/invoices/0006.pdf" does not exist {"exception":"[object] (Symfony\\Component\\HttpFoundation\\File\\Exception\\FileNotFoundException(code: 0): The file \"/var/www/invoiceninja/public/storage/Zh3KnSJFS59Zc9RTh3hOryuBmvX7qNkvYiC1NaJykhKuFevmgxrmEbF1rEU106Hf/IYWF3oXZ94n9oHUTd9mFrXJVeY1X3pfTKWY45uwp/invoices/0006.pdf\" does not exist at /var/www/invoiceninja/vendor/symfony/http-foundation/File/File.php:36)
If I paste the urls above into the browser they work but not it seems not to work in the program. I also suspect that this error might also be the cause of my non PDF generation. I am using snappdf btw. Any help would be gratefully appreciated.
Saved an invoice, but now it can’t delete… It times out but then when you refresh the page it is deleted?!
[2021-10-25 20:48:41] production.ERROR: The file “/var/www/invoiceninja/public/storage/Zh3KnSJFS59Zc9RTh3hOryuBmvX7qNkvYiC1NaJykhKuFevmgxrmEbF1rEU106Hf/IYWF3oXZ94n9oHUTd9mFrXJVeY1X3pfTKWY45uwp/invoices/0006.pdf” does not exist {“exception”:"[object] (Symfony\Component\HttpFoundation\File\Exception\FileNotFoundException(code: 0): The file “/var/www/invoiceninja/public/storage/Zh3KnSJFS59Zc9RTh3hOryuBmvX7qNkvYiC1NaJykhKuFevmgxrmEbF1rEU106Hf/IYWF3oXZ94n9oHUTd9mFrXJVeY1X3pfTKWY45uwp/invoices/0006.pdf” does not exist at /var/www/invoiceninja/vendor/symfony/http-foundation/File/File.php:36)
[2021-10-23 02:38:57] production.INFO: db fails
Thanks for chiming in David. All dependencies for snappdf are installed and I re-installed snappdf with:sudo vendor/bin/snappdf download --force but it is not working just spinning icon.
Times out with 500 error: [previous exception] [object] (League\\Flysystem\\FileNotFoundException(code: 0): File not found at path: uGtnq1hqhbJJr6XZUltjs1WQBAABDXWn/qgYi5m2Pj7aeCedgVq2u4NntjiLexhOZslkRNSy3/m1cFZWiihuE1B5S0oYVEaAfcWzUhKKm4ELtpxKVJ/invoices/0003.pdf at /var/www/invoiceninjav5/vendor/league/flysystem/src/Filesystem.php:390)
[2021-10-26 14:46:53] production.ERROR: File not found at path: uGtnq1hqhbJJr6XZUltjs1WQBAABDXWn/qgYi5m2Pj7aeCedgVq2u4NntjiLexhOZslkRNSy3/m1cFZWiihuE1B5S0oYVEaAfcWzUhKKm4ELtpxKVJ/invoices/0003.pdf {"exception":"[object] (Illuminate\\Contracts\\Filesystem\\FileNotFoundException(code: 0): File not found at path: uGtnq1hqhbJJr6XZUltjs1WQBAABDXWn/qgYi5m2Pj7aeCedgVq2u4NntjiLexhOZslkRNSy3/m1cFZWiihuE1B5S0oYVEaAfcWzUhKKm4ELtpxKVJ/invoices/0003.pdf at /var/www/invoiceninjav5/vendor/laravel/framework/src/Illuminate/Filesystem/FilesystemAdapter.php:159)
Sounds like its looking for a non-existent file in the storage dir. Have you copied the contents of the storage directory over to your new installation? Beware of ownerships/permissions.
OK. I have moved on to a new server using docker. Everything works now EXCEPT PDF generation. It is similar to this thread in that the env app_url and the docker .yaml url are somehow out of sync. Should I start a new topic?
