Gross price in words
Hi. So in poland we need to have gross price in words line. Is it possible to add to invoice?
And is it possible to add table like that under product table? (We need to have that on invoice in poland)
Sorry, it isn’t currently supported.
You can upvote/follow this issue for updates:
Thanks for fast reply. Can i add custom field for that?
And is it possible to add table like that?
A custom product field should work but you’d need to enter the amount in words manually.
I’m not sure if it’s possible.
