I am totaly new in Invoice ninja, a just get it since yesturday, realy great work by the way !
I just get this morning the grey screen beug after testing the flutter version, so i can only acces it from mobile app or pc app, but no more from https who appear grey. i have take a look on solution, but i am a little lost, can i just back flutter off somewhere in parameters ? I push last update too, but same result
yep ! maby my in-vhost.conf… Uncaught (in promise) TypeError: Failed to register a ServiceWorker for scope (‘https://XXXXXX.fr/’) with script (‘https://XXXXX.fr/flutter_service_worker.js?v=5.8.46’): A bad HTTP response code (404) was received when fetching the script. (i change the domaine by XX)
“UPDATE accounts SET set_react_as_default_ap = 1;”
Did i need launch this from invoiceninja.db cointainer terminal ?
i try the native method to make it pushing in script.sql Update commande line, and try send it to the invoiceninja-db coontainer with mysql -h 172.19.0.3 -p 3306 -u root -p < /tmp/script.sql but dont get the root passsword, i try with it with ninjauser/ninjapass. Sorry i was totaly noob lol
Are you seeing a similar 404 error for the flutter_service_worker.js?
Also, is there a reason you’re using the Flutter web app rather than the React web app or the Flutter desktop app? Over time we plan to phase out the Flutter web since the React app is a better web app and the Flutter desktop app is identical to the web app only faster.
We are using the desktop app for everyone else but I’m using a MacBook running Catalina which doesn’t support the current app. Hence I need to access from the browser.
I’m depended on maihai’s release of the updates for invoice ninja on unraid so usually a day or two late from the offical releases.
Will post back with an update after I’m on the latest release.
The latest version of the framework we’re using dropped support for older versions of macOS, there isn’t much we can do. In the not too distant future we’ll likely deprecate the Flutter web app but hopefully we can get the React app working for you before then.
