We are trying to integrate GoCardless with Invoice Ninja. We found the setting to create new Gateway
https://prnt.sc/26ordsh
We are creating a new access token in GoCardless but we need clarification if the taken is read only or read and write?
Thank you
Chubby
February 4, 2022, 8:17pm
We added GoCardless recently, you need to set as read/write.
Hi @Chubby , thank you very much for your reply. Do you have any documentation for GoCardless? Do I still add users in GoCardless or can Invoice Ninja create the customer on GoCardless via the api call?
Chubby
February 5, 2022, 9:48am
4
Unfortunately No, I reached out to GoCardless support, firstly to establish IN was a on their list, they confirmed they are. There is no specific documentation for IN and it was a matter trial and error until I got it to work. I do remember having to create the token and endpoint several times before I got it right. This might help you, when the created token and entered into IN it creates an webhook endpoint, this needs to be inserted into webhook endpoint on the Gocardless website. I wish I could help you more.
Chubby
February 5, 2022, 10:11am
5
Regarding your question - Do I still add users in GoCardless or can Invoice Ninja create the customer on GoCardless via the api call?
You do not have to add the the customers in Gocardless as the PayNow button invites your customers to create a DD mandate through IN. As I understand it, once they register, you go into Gocardless control panel and add them to a Plan which your customer authorises. You also get the âinstant paymentâ option for one off BACs payments which I think is great. I donât offer the PAYNOW to all customers but this is a different subject.
Here is what I did to create a GoCardless option:
When to the âOnline Paymentsâ section
Clicked âConfigure Gatewaysâ
Clicked the â+â in the and selected GoCardless
When in GoCardLess Developer section I created an Access token READ/WRITE
Added the token to the section in Invoice Ninja then saved it
After it saved a webhook was created and I used that to create a webhook endpoint in the GoCardless dev section
Copied the webhook secret from the GoCardless webhook endpoint and pasted it as the webhook secret in Invoice Ninja. I then enabled the Bank Transfer, Direct Debit, and Instant Bank Pay under the invoice Ninja setting and clicked âsaveâ.
Tried going into a customer client page and adding a bank account, but I just get a 500 error.
What did I do wrong?
Here is the output from the 500 error⌠Do we need to be on the GoCardlessPro plan for this to work?
[2022-03-04 20:29:47] production.ERROR: Class âGoCardlessPro\Clientâ not found {âuserIdâ:23,âexceptionâ:"[object] (Error(code: 0): Class âGoCardlessPro\Clientâ not found at /var/www/site.com/app/PaymentDrivers/GoCardlessPaymentDriver.php:90)
#0 /var/www/site.com/app/PaymentDrivers/GoCardless/ACH.php(44): App\PaymentDrivers\GoCardlessPaymentDriver->init()
#1 /var/www/site.com/app/PaymentDrivers/GoCardlessPaymentDriver.php(52): App\PaymentDrivers\GoCardless\ACH->__construct()
#2 /var/www/site.com/app/Http/Controllers/ClientPortal/PaymentMethodController.php(58): App\PaymentDrivers\GoCardlessPaymentDriver->setPaymentMethod()
#3 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\ClientPortal\PaymentMethodController->create()
#4 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction()
#5 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Routing/Route.php(254): Illuminate\Routing\ControllerDispatcher->dispatch()
#6 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Routing/Route.php(197): Illuminate\Routing\Route->runController()
#7 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Routing/Router.php(695): Illuminate\Routing\Route->run()
#8 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#9 /var/www/site.com/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#10 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\QueryLogging->handle()
#11 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#12 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#13 /var/www/site.com/app/Http/Middleware/Locale.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#14 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Locale->handle()
#15 /var/www/site.com/app/Http/Middleware/CheckClientExistence.php(33): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#16 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\CheckClientExistence->handle()
#17 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(44): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#18 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Auth\Middleware\Authenticate->handle()
#19 /var/www/site.com/app/Http/Middleware/SetDomainNameDb.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#20 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\SetDomainNameDb->handle()
#21 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(78): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#22 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#23 /var/www/site.com/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#24 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#25 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#26 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\Session\Middleware\StartSession->handleStatefulRequest()
#27 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Session\Middleware\StartSession->handle()
#28 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#29 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#30 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#31 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#32 /var/www/site.com/app/Http/Middleware/SessionDomains.php(32): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#33 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\SessionDomains->handle()
#34 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#35 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Routing/Router.php(697): Illuminate\Pipeline\Pipeline->then()
#36 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Routing/Router.php(672): Illuminate\Routing\Router->runRouteWithinStack()
#37 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Routing/Router.php(636): Illuminate\Routing\Router->runRoute()
#38 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Routing/Router.php(625): Illuminate\Routing\Router->dispatchToRoute()
#39 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(166): Illuminate\Routing\Router->dispatch()
#40 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#41 /var/www/site.com/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(55): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#42 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#43 /var/www/site.com/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(52): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#44 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#45 /var/www/site.com/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#46 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\Cors->handle()
#47 /var/www/site.com/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#48 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle()
#49 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#50 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#51 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#52 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#53 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#54 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#55 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#56 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#57 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#58 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#59 /var/www/site.com/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#60 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Sentry\Laravel\Tracing\Middleware->handle()
#61 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#62 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(141): Illuminate\Pipeline\Pipeline->then()
#63 /var/www/site.com/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#64 /var/www/site.com/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle()
#65 {main}
david
March 5, 2022, 9:06pm
9
@xtekrepair
Iâm assuming you are on the latest version of the app?
The error being reported here is that the system cannot find the client library at all. GoCardless only has one PHP client library which should work for all users not just âProâ
Can you check that the library is available in vendor/gocardless/gocardless-pro
If you have root access to your server it may also be useful to rebuild the autoloader by running the following:
composer dump-autoload
Thanks I did confirm that it was missing. I am updating to the latest version right now to see if that corrects the issue. Not sure why it was missing though. I was using v5.3.61
I updated to the latest version and the client was still missing, so I downloaded from invoiceninja.org and uploaded the missing files. I then updated permissions to the folder and ran the composer dump-autoload.
I am still getting the same error in the log⌠and of course the 500 errorâŚ
Here is latest output in the log:
[2022-03-07 17:49:53] production.ERROR: Class âGoCardlessPro\Clientâ not found {âuserIdâ:147,âexceptionâ:"[object] (Error(code: 0): Class âGoCardlessPro\Clientâ not found at /var/www/site.com/app/PaymentDrivers/GoCardlessPaymentDriver.php:90)
#65 {main}
xtekrepair:
GoCardle
I had to run the following commands to make this work:
composer self-update
composer update
Then I had to chown with the correct permissions.
I was able to make it work then.
FYI Also, I wanted to setup some customers with GoCardless and some with CC through Authorize Net.
I found a settings option under the client account, is allows you to remove a payment gateway specific to a client. This made it so some customers can use both Auth and GoCardless, and some can use one or the other.
