Couldn’t find it in the documentation - are there instructions for setting up GoCardless? Does the API need to be read/write or just read?
What URL do we use for the webhook endpoint (on the gocardless side)?
Thank you.
Thank you.
@david can you please advise?
Through trial and error I believe I figured it out (as far as the webhook)… however if you can advise on the read only vs read/write for the API that’d be great as I couldn’t find the documentation.
@BBComputing I believe you’ll want to enabled Read/Write for the API. And as you have noted the webhook URL is found after configuring the gateway in Invoice Ninja.
