Hi there,
i found several non / wrong translated strings in the Software, and i would like to work on the translation.
Where can i find the language file / table?
How can i give my work back to the developers/users?
Regards Java-Jim
Hi there,
Regards Java-Jim
That would be great, thanks!
The translations are maintained here:
Great, i will work on it. I registered an free 14day Transifex accountâŚ
Translated nearly all untranslated german entries.
How can i update this language file to my installation?
The language files are updated with (most) new releases
Is it possible to download the texts.php from Transifex and save it under ./ressources/lang/de/?
I can not find a download link at TransifexâŚ
Sorry, Iâm not sure if they support it
It is possiblie, after complete the account activation. There is a link âDownload for useâ.
I put the texts.php file to ./ressources/lang/de, did php artisan optimize, opened url with /?clear_cache=true#/, but the translations did not arrive in the application. What can be done?
Where can i translate the client portal?
All texts are managed in Transifex
In the same texts.php file? I searched for text expressions found in the client portal, but they donât appear in Transifex.
Maybe not all strings in the Client portal are fully set up for language switch?
Most strings are fine but something like âShowing 1 to 1 out of 1 resultsâ, âNo results found.â, âPer Pageâ or the Page Client Information âUpdate your personal informationâ arenât translated.
As this is the face to the customer, this should be fully translateable.
Understood, weâll look into itâŚ
cc @ben
Thank you very much!
Hey there. Thanks for reporting this, weâre internally having a discussion on how-to handle this. Iâll update you here once we conclude it.
Thanks!
Hi ben,
i got the newest release and downloaded the texts.php from transifex. Many strings aren´t translated although the are defined -> âtask_settingsâ => âAufgaben Einstellungenâ but the Frontend shows âTask Settingsâ.
Thatâs totally weird. The only behaviour that is known to me, if the translation doesnât exist for one language, it may fallback to English.
Whatâs the language youâre trying to use & where do you see that text?
The admin portal needs to be rebuilt for the language files to be updated
ok, but which command ânpm installâ, âcomposer updateâ, âphp artisan optimizeâ ?
As mentioned previously I suggest waiting for next release, if you want to try to build it the code is here. Note: youâd need to update lib/utils/i18n.dart.
