hello, for now my ninja work very well, but pdf take about 5/6 seconds to generate, i try all 3 snappdf, phantom and hosted_ninja and take same time, so i think it something is wrong whit invoice ninja. I see that a few versions ago.Usually took about 1 second, and now 6
a second question, why the design of recoring invoice is not the same of invoices and quotes? it is a bug?
if help this is my env file
Unsure what could be causing such a slow generation time. There should at least be signficant differences in times between hosted_ninja and snappdf… with hosted_ninja your system only generates the HTML and then sends that to our servers for PDF generation so taking in the latency overhead depending on where you are in the world it should only take ~2 seconds max to get a response from hosted_ninja.
This may indicate the overhead is in the generation of your HTML.
@david i did several tests and hosted_ninja takes same time 5/6 Seconds i try change the design to the clean without changes and same think that’s why i think it’s weird, all 3 generators take the same time
@david maybe you are right, i change the network maneger and now generate in 4 seconds, i will check my connection later.
now my only question is why the recuring invoices dont have the same design?? cant change the design of recuring invoices?
@xoo@david ok i remove the trailing slash and edit and save the recurring invoice, and in my setting i have all design for the creative, but recuring generate the clean model.
Neither can I. But you are talking about a separate Recurring Invoice design setting. I only see Invoice, Quote, Credit and Purchase Order design settings, no separate Recurring Invoice Design. Am I missing something? (And yes, I left PO Designs as “Clean”, because I haven’t had a use for PO’s until now.)
@xoo yes that’s it thank you, i never see that option, i think that was better that option is in general settings, like we define the default invoice or quote design,need to edit all recuring but ok problem solved
