No matter what I do, I can not get blockquote to work when I reply to forum posts.
Here’s a test of blockquote in a new post:
This sentence should display as a blockquoted element.
Thanks!
Edit: yep, as expected, the
tags don’t seem to affect anything (visually, at least).
In this instance I am viewing/editing on Firefox 52.9.0 ESR
January 26, 2019, 9:20am
Try a back-tick ` at the top and bottom
<test>test</test>
OK, next line is a blockquote
this is a blockquote
January 26, 2019, 9:22am
4
I was wrong about using 3, you just need one on the first and last lines.
Interesting!
The backticks work.
Can you change the “b-quote” button to insert backticks instead of <blockquote>?
January 26, 2019, 9:24am
6
Not sure but it looks like the ‘Code’ button works correctly.
Yes, I have successfully used the code button a number of times.
January 26, 2019, 9:25am
8
Ok, thanks for the feedback! We’ll look into correcting it.
Blockquote and code should look a bit different, shouldn’t they?
A single tick would be for code
Let’s see how these look . . .
Note how the blockquote has lines extending from each side.
Meanwhile, items market “Code” just have a “simple” bounding box . . .
three tick test
and
two tick test
multi-line three tick test<code></code>
If you look at my post immediately above this one you will see that a “clean” multi-line “bounding box” blockquote does not seem possible at the present.
I don’t know whether that is something you can improve or whether you need to forward that to your forum software developer . . .
Thanks in advance!
January 29, 2019, 7:10am
15
Thanks, we’ve forwarded this issue to the developer who set it up.
