I have a problem with invoices footer rendering. In the Invoice Desing, everything works well and the footer gets rendered at the bottom, but then I download the actual invoice - it’s always empty.
Yep, it’s a custom design. Plus it’s not getting rendered regardless of footer content. I tried just:
<div id=“footer”>
Footer
</div>
I can share the template itself I’m using.
Is the footer displaying on a regular standard invoice design?
If you are using a custom design, you’ll need to declare the entity variables so that the footer content is displayed
ie
$entity_footer
