Hey guys!
I’m using a local installation of invoice ninja 4 to send some recurring invoices, but today I noticed a bit strange behavior (at least for me).
I’m using the client’s salary plan (usually Net 7)
Each month the invoice is sent a day or two after the day of the previous month, for example:
In May the invoice was sent on the 7th;
In the month of June the invoice was sent on the 8th;
In July the invoice was sent on the 10th;
Would this be the expected behavior of the system?
If so, I know that in the configuration of the recurring invoice there is the option for payment on a fixed day, but I would like the invoice to be sent 7 days before the due date, is this possible?
My cron jobs are executed on 5am and 6am every day, with timezone America/Sao_paulo at server and at app.
Helo!
Thanks for the feedback, what would be the internal workings of the routine, for me to calculate more or less the cron times?
I ask, because the server runs in America/Sao_Paulo (-3:00), and the app too, theoretically the timezone would not be a problem, what time do you recommend?
But a question, would it really be the case to run cron later?
What file could I look at to try to figure out what the reason for this behavior is?
In addition, version 4 has integration with a Brazilian payment service called PagSeguro, can you tell if this integration has already been implemented in version 5?
