Is there a way to filter the tasks by the exact project, or some way to view only the tasks for one project other than the search filter? I ask because the search filter is quite generous and always shows something not in the project I want and that gets confusing. Just want to go into a kanban for one project.
Ok, i think I figured it out.
- Go to tasks
- Change the view to List view (icon at top left of tasks screen)
- Open the Preview Pane
- In the task list, click on the name of a project
- In the preview pane, click on the name of the project
- Then change the view to kanban
Is there a quicker way?
You don’t need to change the list view. You can use the Kanban view, click “View” on task and then click the task project. Does that help?
I see, yes that works, thank you!
