would it be possible to intergrate the function to import tasks from a cvs file?
Best regards
aru
Best regards
aru
Agreed, this would be useful.
@david should they create a GitHub issue or is it already on your backlog?
Github feature would be great, thanks!
Appreciate your agreement…
shall I add an issue there ? – Issues · invoiceninja/invoiceninja · GitHub
BR
aru
Yes, that’s the correct place.
Thanks!
Done
can you provide a sampple of a csv file you’d like to use so i can inspect the mappings please
