Running Invoice Ninja - v4.5.17 | White labeled - Self Hosted
Ran into an esthetics issue with the Company Logo setup under Settings / Company Details.
A wider and larger logo that looks good on the Client Dashboard page looks terrible on the Invoice.
Request is for the ability to upload 2 versions of the logo, one optimized for the Client Dashboard and one for Invoices.
Thank you.
One possible workaround is to use a custom design and embed a base64 version of your logo.
https://pdfmake.github.io/docs/document-definition-object/images/
Interesting… I will have to try that. Thanks Hillel!
OK, that worked!
Can I also use base64 image code for the top of the email notifications for invoices going out to clients?
5
Sorry, I don’t believe so
