Version ie v5.13.44
Environment VPS Zip
Checklist
- Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com
- No, seems to work on demo
- Have you searched existing issues?
- yes
- Have you inspected the logs in storage/logs/laravel.log for any errors?
- no errors
Describe the bug
It appears the dynamic task rate fallback hierarchy is not behaving as expected when assigning a client to a new task. Selecting a client whose individual “Task Rate” setting is blank overrides and clears out the pre-populated Company Default Task Rate.
Steps To Reproduce
Set a global default rate under Settings > Task Settings > Default Task Rate (e.g., $50.00).
Ensure a specific client has no custom hourly/task rate set (the field is left completely blank in client settings).
Go to Tasks > Create Task.
Observe that the Rate field correctly pre-fills with the company default ($50.00).
Select the client from step 2 in the client dropdown.
Expected Behavior
Since the selected client has no custom rate specified, the task form should maintain the Company Default Rate ($50.00), or fall back to it upon saving.
Actual Behavior:
As soon as the client is selected, the reactive form reloads and clears the Rate input field (setting/leaving it blank). Upon saving the task, no default rate is inherited or calculated, effectively leaving the task rate at $0.00.
Additional context
Browser cache cleared and tested across multiple browsers.
Workaround currently requires manually re-entering the hourly rate on every new task or explicitly setting a rate on every individual client profile.
